9073
Hi,
my old 90 has been giving me problems with the oil pressure for some time now. Now it has gotten to the point where it will not idle with out the engine idiot light on.
i figure it is time to do bearings
would you recommend doing all the bearings (including camshaft) the main bearings or just the connecting rod bearings
should i remove the engine of pop the bearings in from underneath (assuming im not doing camshaft bearings)
or should i just keep runing her or replace the oil pump
the vehicle has supposedly 100,000 miles on the engine but a max of 208000
thanks matt
thanks matt
