spencnaz
- Joined
- Jul 26, 2006
- Posts
- 314
- Reaction score
- 0
Truck blew the gasket on the driver's side cylinder head. We worked from 9am to 1am last night on the job.
Talk about a big job, sheesh. We had to loosen up the intake manifold to get the cylinder head out as the Hypermax turbo oil return line was in the way of removing the intake manifold. We got the cylinder head out, changed the gasket, and inspected for any cracks as best we could. I really need to be able to remove the intake manifold.
Cylinder head looked just fine, pistons were nice and clean the the bores were in fine shape.
We wiggled the head back into place, (took us 3 tries since the gasket was being lifted off the rear dowel by those 2 head bolts at the back that are such a pain to install.).
At about 1230 last night as my friend was putting the intake manifold bolts back in and I was adding coolant to the radiator, we hear this sound of water hitting the shop floor.
There is coolant flowing out the back of the cylinder head! I can see it pooling up around the glowplug controller and the two rear cylinder glowplug area holes! Did I screw up the head gasket?
Talk about a disappointment! So I call again on you to HELP! It's obvious that I need to remove the head yet again.
Any one know how to remove a Hypermax turbo without disassembling the whole engine? Should I just take the turbo off from turbo mounting flange? I doubt this is a cracke head, the truck wasn't leaking any coolant previously.
