Headlight weird issue.
chillman88
Central NY
Are they like the 91 down trucks where there's a little tiny nub on the switch you press to release the knob?
Thatoneguy
Boerne, Texas
FINALLY GOT IT OFF! I just pulled hard. Screw the stupid pushy-clip thingy. But for some reason even after I just installed the new pigtail and switch, my headlights won't go on. High beams work, headlights are still MIA. When replacing the pigtail I transferred one wire over at a time, and I double checked, so I know it's good.
Sent from my Moto Z (2) using Tapatalk
plug back in the old switch and see what happens.
So you think the problem could be a faulty new Switch?
"new" these days may not mean "good"
if the problem is still there after the swap out, you missed something in the rewire work.
if the problem goes away, the problem is in the switch.
that's about as definitive as you can get without extensive contemplation.
chillman88
Central NY
I'm going to jump in for a second...
How are the 92+ Trucks wired? I had an issue once with my floor dimmer switch that caused my lights to go COMPLETELY out, not just switch from low to hi.
Could there possibly be an issue in the multifunction switch? I realize wiggling the light switch used to work but I'd think it worth considering...
Danielle
No, it's not finished
Dirty Jersey
How did I not know this kit was a thing? I just bought all the stuff and started doing this the "other way" haha
Sent from my VS835 using Tapatalk
Thatoneguy
Boerne, Texas
Ok... So tried the old switch, still no headlights. New switch back in, still no headlights. Checked fuse and it looks good. Anybody got anything else? Lol high beams, running lamps, etc. All still work. Just the freaking headlights.
Thatoneguy
Boerne, Texas
Just tried the multimeter with ground on battery negative and stuck the positive in all three spots on both of the headlight connectors. No power to them. I feel like I'm missing something obvious. I have the bronco graveyard wiring kit on the way so that should fix it right?
chillman88
Central NY
No because the relay kit uses the existing wires as a signal to feed the relays.
Did you ever check the multifunction switch that does the high beam switching?
ntjapkes
