Mikes91
Does the headlight relay mod only take the load off the switch when headlights are used (i.e., doesn't affect the switch as far as trailer lights go?)
How would I go about taking care of the 15-20 or so lights on my horse trailer, too? Wiring up the parking lights? Is a 20A relay sufficient? There are lotsa lights on that trailer, plus 2 or 3 large interior lights for the horse section and tack room.
Is a fuse needed on the trailer portion of the circuit? The relay can handle xx number of Amps... what about the fuse in the fuse box? I suspect I'd blow the relay before blowing the fuse in the trucks' fusebox if I try to pull too many amps?
Also, can anyone post specific part numbers for the mod? Relays, fuse blocks, etc.?
Thank you,
Mike
Thank you,
Mike
