BIG DAVE
OILBURNER FOR LIFE!
where can i find some head stud's for my 7.3 IDI and what head gasket's should i run and should i coat them, and with what
Thanks, Dave
Thanks, Dave
On the topic of these bolt I have some questions.
1. Since these bolts are too long, is multiple washers used to make up the difference?
2. Does the threaded part of the bolt hit the bottom of the block holes?
3. If not, has anyone tried chamfering or countersinking the holes a little to bring the
stud down more?
4. Didn't someone in the past use studs purchased at Caterpillar on their engine?
These studs fit. They stick up out of the nuts just a little too far. On my motor the inside of the deep socket bottomed out and rolled the top thread unless I kept the socket perfectly lined up. No you can't use 2 washers. The bottom threads have the chamfer and that will bottom out in the block like its supposed to. Franklin... Yes it does matter if the studs are too long. They are not threaded all the way down the shaft of the stud and the top thread is 1/2x20 and the bottom is 1/2x13. I placed my heads on the block first. Then I installed the studs using a allen socket to speed things up and get them tight in the block. Others installed the studs, then the heads. Its up to you as to how you do this step. About the only way you could remove the heads when studs are installed is to lift the cab up off the frame about 6 inches. Even then it will really be a tuff job and not worth the extra work... If you have a lathe just cut off about 1/4 inch off the top fine threads and they wont be an installation socket issue like I had.
