richtrailrider
thanks...head about to be pulled to reclame glow plug tip which broke and stayed in head. does the valley pan aka. intake manifold gasket come off. does the fuel pump come off too.
wow that was fast! did not know about the nut in back of valley pan good info so vp and ip do come off.
more help please! a control switch "glow plug temp/timer relay'" - a gray multi pin connector - threaded into the drivers side rear cylinder head coolant jacket was disconnected at purchase. a push button on the dash now activates the glow plug relay selinoid on the fender well. what do you think ?one more guestion . are autolite glow plugs good?
more help please! a control switch "glow plug temp/timer relay'" - a gray multi pin connector - threaded into the drivers side rear cylinder head coolant jacket was disconnected at purchase. a push button on the dash now activates the glow plug relay selinoid on the fender well. what do you think ?one more guestion . are autolite glow plugs good? 84 6.9 diesel thanks rich ***head update*** removed precombustion chamber and glowplug tip now removed, torked head and moving on and on ++++ Do i erase previous questions and if i do how do i erese.
