Has anyone ever thought about.....
160k87F250
not rocket science
York, PA
It's got me thinking. What should I do with my 77 F250 2wd. I was thinking about a race truck. Built 460, C6, 9'' rear, ETC,ETC. Maybe I should make it a diesel. IDI of course, I hate cross contamination of brands, but that's just me. 6.9 or a 7.3, turbo, C6 w/ gear vendors, I forget what rear is in it. I would hate to put a body lift on a 2wd.
John
tonkadoctor
none ya bidnes
Put an IDI into a Dodge:rotflmao :confused: :dunno
Why, so you can finally beat a Dodge at the stop light with your IDIT Ford.......... What happened, you get spanked by a Dodge pulling out of school the other day:D ;Poke :popcorn
FordGuy100
Silverton, OR
:rotflmao No, I've never raced a dodge. I have no doubt that around the school (short little streets), that I could take on a first and second gen 12valve that was stock. I've driven a 97 Dodge with a stock 12valve, and my truck has more balls from 0-30mph (hence why I said short little streets).
It was this other guy on another website had his avatar saying something like "why do you never see a powerstroke in a Dodge?" Kinda irked me enough to ask if anyone had ever thought about doing it.
tonkadoctor
none ya bidnes
The why is prolly..... Why would they pull an engine that is common to see last 500k - 1 million miles before a rebuild and put one in that typically lasts 350k - 500k miles. The dodge trucks wear out before the engine does.
Much less moving parts to break in an Inline 6 vs a V8 too.
fx4wannabe
Chattanooga, TN
I agree, Cummins motor is a much better engine I think. Plus its proven track record. I have always said if they put a Cummins in a Ford chassis that would be the only truck on the road.
BigRigTech
Diesel junky
Nova Scotia, Canada
I beg to differ on the longevity of the Cummins, I've seen several blow up with much less that 500K on them....And I mean blow up - vented the block and "came from together"....:rotflmao IDI's drop valves, ISB's blow up and crack cylinder bores, another common Cummins theme.
tonkadoctor
none ya bidnes
Out of curiosity. How many of those were in Medium duty trucks vs ram pickups, fleet owned with multiple drivers vs 1 owner trucks. That's a fairly small engine to be trashing around in a freightliner chassis with a lead footed company driver that doesn't care because it's not his.
BigRigTech
Diesel junky
Nova Scotia, Canada
I've seen them both ways - company and brokers....Doesn't mean a thing. The most I've seen on one it a 2-5 ton is 500,000KM and it's usually toast at that point. Lets not forget the ISB was put in medium duty trucks before the Dodge ram ever saw one. From what I've seen they really don't last any longer than an IDI or PSD engine - still a parent bore engine intended for one life cycle. I'm not saying the IDI or PSD is better than the ISB, they are all the same.....Except for the HP potential in the ISB - it is a step above in that class thanks to the aftermarket.
87F250
Santa Cruz, Ca.
John
Oh the irony.
Nanohawk
