antiqueford
I called up the bed manufacturer and asked how much their hitches are rated for. The answer I got was. "Whatever the ball can handle, like 5000lbs I think." ???
The drop, as well as the bed frame rail are 4x1.5" channel. The plate is 3/8".
The plate is bent because the ball appears to have been loose for some time now.
What do you guys think this is capable of handling? Of course, at the very least I will flatten the plate and reinforce it with an extra 3/8" piece.
What I really need is a receiver tube in there. I can't imagine it's up to class V specs though.
If I were to add the receiver tube, its a 9" drop from bottom of frame to hitch plate, so I'd use 3/8" side plates off the bottom of the truck frame, and run a 4" tube crossmember. Then the receiver tube would be welded through the crossmember and also fully welded where it passes through the existing plate.
I don't plan on hauling more than 10k, but I'd like to be confident my hitch can handle it.
Just wanted to run my ideas by you guys and see if anyone has any input for me! Thanks in advance for any ideas/advice.
