GRRR! I've got black death!
DaytonaBill
I have a variable speed controller for my electric fans. i have a jaguar dual pressure switch installed on my high side line. the fans will ramp up based on head pressure and temperature. the fans will run anytime the a/c compressor is running though.
Ahh!!! I must've read that wrong...
Well, I think I will do it using a speed switch that is set to receive pulses from pins 4 and 5 from the RABS connector. Might have to tap into the PSOM if the signal frequency from the VSS is too high for the speed switch. Don't know at this point, more research is needed...
It has to have the cut off frequency set and then I can hook up a relay to it to run the fans... It has cut off points for under speed and over speed, so I should be able to make that work. Don't know how expensive it is... Here is the manufacturers website, clicky.
For now, I'll just switch the condenser fan from the dash via a relay... When I start the rear air project, I'll incorporate the speed switch into the system... Whee!
DaytonaBill
if you get bored, maybe you could snag a pic of the evaporator mounting stuff and or measure the bolts :)
I think i can get it together but it would help. Please and thanks in any event
Sure, I'll get that for you before noon, will that work out for you?
Do you need the connection sizes too?
I'm sorry rhkcommander, I guess my new condenser won't be here 'till tomorrow...
You did mean the condenser, not evaporator, right? :confused:
My evap is in the heater motor blister on the passenger side of the engine, you know...
I'm not doing anything to my evap, other than the flush I gave it and when I attach the new accumulator to it, the new orifice tube will go in at that time...
DaytonaBill
[RANT ON] -cuss:mad:-cuss:backoff
Grrr!
This is maddening! Now I'm told that my condenser won't be here until tommorrow and we have 50% chance of rain tommorrow!!!
I've never seen the parts stores so disorganized and abusive of the parts that are being shipped.
I didn't say this before, but about 4, yesterday, I went to check to see if it came in and sure enough, it was there!
So, the first thing I noticed was cellophane tape on the lid... "Red flag"...
I opened it up and it was damaged!
For your information, this is a brand new Visteon condenser and it was made in Thailand!!! I wish we could start producing our own stuff again! Crappy labor equals crappy products!!! ESPECIALLY if they know it's for the Americans...
It looked like UPS or FEDEX had shipped it! The outlet tube was bent and there was no way I was going to accept that. That's why I was supposed to get a new one today, but it seems that they can't wrap the new shipping schedule around their mind... Thusly, they give me the wrong time and date of arrival...
Grrr! I can't wait for this to be over... The imbeciles walk among us!!! [/RANT OFF]
There, now I feel better...
itsacrazyasian
residentcrazyasian
boca raton, fl
Unfortunately, someone played a switch a roo on you. Thailand built condensers are usually either spectra, csf, or other economy brands.
Visteon is built either in Korea, Brazil or Mexico. Thats with any condenser on the F-series trucks.
DaytonaBill
Really? Any way I can find the true brand somewhere on these condensers? It's supposed to be here at one o'clock... Thanks...
itsacrazyasian
residentcrazyasian
boca raton, fl
visteon will ALWAYS put a sticker on their parts. Vistapro is the new company, they make products under a few different names. Look for a stamp/sticker. the part number is usually on the condenser. see if it matches up.
DaytonaBill
Thanks, I'm glad to know that and will confront them about it. I'll bet they didn't know and that it's all being done in the upper management, where ever that is...
DaytonaBill
Well, Rockauto has them under Vista-pro with the same number as Advance Auto, So I will look for the sticker, but I swear the box said made in Thailand... We will see...
DaytonaBill
Ok, I've accepted the condenser. It is made in Mexico, the sticker is on the outlet arm and (bonus!) no rubber feet... Finally, a condenser that resembles factory stock!
First thing in the morning I'm going to start...
rhkcommander, I'll take some pictures of the Condenser mounting flanges and take the measurements between the holes. I can't figure out why you would want this information though... Everything should become apparent as you go...
I'll PM them to you tomorrow nite...
C-ya!
itsacrazyasian
residentcrazyasian
boca raton, fl
Told Ya. LOL.
I've been doing this a while. I know what to look for in parts now. Been SCREWED before by someone playing a switch a roo and idiot parts store guys not knowing the difference.
DaytonaBill
Told Ya. LOL.
Thanks, pal! I sure appreciate all of the help you have given me... It's going to be a fantastic feeling when I finally consummate my grand experiment with this refrigerant! I'm very confidant this was the right path to go since the R-12 is out of reach financially. Thanks again!
:D
DaytonaBill
Well, so much for consummating the grand experiment with this refrigerant...
It took me fifteen hours from the time I started Thursday morn to the time I finished Thursday night. There was a lot of work to do as I had cut my fan guard in half to do away with the extreme hassle of removing the fan with the one piece fan shroud in the way. But I made that work... Now all I have to do when I take the fan off, is to take the top half of the shroud off and I made a system that holds the large flappy side of the shroud together so the two halves don't tend to 'flap' past each other as the fan is working...
I found that the idler pulley was starting to grind in the bearing, so I replaced that. I had stripped the threads for the bolt that holds the other pulley on the belt tensioner, so I replaced that as well. Mine has the hydraulic shock on it.
I then left the fan off and tilted the radiator to the engine (cardboard between the radiator and the water pump shaft!!!)...
Pulled the old condenser off and just this morning, I discovered that it was for a 1994 F-350 (which explains why it came with the rubber feet and tabs way too big for the bolts that held the original condenser in place) It was a Visteon Part # 1157. It should be Part #1155 for serpentine or #1055 for tube and fin...
Went to install the new 1055 and can you believe it? I had to trim some metal from the outlet tube reinforcement arm to make it fit! GRR!!! Also had to adjust the mounting pad that are screwed on the condenser... Made in Mexico!!! What's the matter with them? Don't they use jigs when making these parts?
Ok, it's 2:30 or so when I get that done. Now for the blowing out the hoses to make sure no bugs are trying to make new homes... Of course I blew out the new condenser before I put it in... So I get to the evaporator... And blow it out... Bingo! Out comes a whole cup of flush!!! All over my engine bay!!! :frustrate I spent at least 15 minutes blowing that out after I flushed the first time!!!
Oh well, I'm just glad I checked for bugs in my condenser, that kept me from losing a brand new compressor... So I air flush the condenser for another 15 minutes, popping it to make sure I got the last of the flush out. You can never be too careful concerning these systems...
I precharge the new compressor and this one has a sticker that says to put only 3 ozs of oil in the suction side. I put in a total of 9 ozs of Supercool PAG 46 throughout the system with no dye. Don't need to put any in, all new accumulators have desiccant pads with dye in them.
Now, it's 5:30 and I'm ready to vac the system down. I pull down to between 25 to 50 microns for twenty minutes (you have to have the gauges installed for this and for charging also and make sure you zero out the low side gauge, too). Then I turn the shut off valve on my vac pump and turn it off (in that order) and I let it sit for ONE hour!
Yay! No leaks! The needle didn't even budge! Now I'm ready to suck it out for TWO hours... I want to make sure that ALL of the air and moisture is evacuated out of the system before I charge it with refrigerant!!!
8:00... Now I'm getting my cans and scale ready. I made a homemade thingamob® that holds the cans upside down nicely and sits on my scale that reads out in grams. ES-12 can be charged into the system in liquid phase and that still won't slog the compressor at all. It is a lot quicker too!
The gauges and hoses are still in vacuum and now it's time to connect the yellow hose that was connected to the vac pump, to the can. This is also the charging hose. I weigh the can with the hose attached to it, note that down (make sure you keep track of how much you charge in grams, it requires 396 grams for a full charge)... Discharge the contents of the can (upside down) into both ports with the engine and compressor NOT turning...
Close the high side valve on the gauge and connect the cycling switch and compressor. Start your engine (I drove around for ten minutes before I started the charging process because I wanted the engine warmed up to finish the charging.
After I started the engine, I turn the A/C to MAX with fan wide open. Stuck a digital thermometer into the driver's side center vent and monitored the temps.
I unloaded a full 396 grams and shut off the can, disconnected the hoses and took it out for a test ride...
It's 74 degrees out and I drive for 2.5 miles. the lowest the temp got down to was 45 degrees. Hmm, that's only a 29 degree drop. I wanted at least a 45 degree drop. So I turn around and head back to the house with the fan all of the way down to low. I get home and the vent is blowing 32.5 degrees... In 74 degree weather!!! 50 degrees in 100 degree weather with the fan on full blast is my goal, so i shut everything down and put everything away for the night. It wasn't a complete success, but it works as well as most 134 systems, soo...
Ok, there's a few mistakes I made which didn't become apparent to me until later...
The first and BIGGEST mistake I made was I used 134 gauges and got adapters for them so I could connect directly to the R-12 fittings that come stock with these A/C lines. The reason I used these adapters was two fold. One, you are not supposed to use the 134 fittings unless you are indeed using 134...
Two, in my experience, the high side fitting tends to leak and I always blamed it on the 134 fitting, so rather than buy gauges for R-12, I cheaped out and got the adapter hoses that connect the 134 gauges to the hose fittings. I got rid of the 134 fittings and I thought it was a good idea, but uncle Murphy likes to move in mysterious ways...
Well, I left those adapter hoses connected to the A/C LINES with the safety caps on them and went to sleep. The next morning, I started to connect the gauges up, with the low side first and then when I got to the high side, as I went to take the safety cap off, I noticed the air in front of the fitting was shimmering, the fitting was leaking! I connected the hose and then checked the static pressure and it was 35 psi!!! :frustrate
My adapters for my 134 gauges let most of the refrigerant out overnight while I was counting the sheep!
Don't leave anything hooked up to the A/C lines, the gremlins will smell stupidity and jump up and down on it like kids on a mattress!!!
Ok, my first mistake was not taking all of the gauge hoses off the A/C line and that cost me refrigerant and I just had enough to charge the system once, not twice!!! So I have to order some more and wait for it to get here... And now I have no idea how much is in there, but all is not lost!!!
I have researched using another method of insuring that your system is full of refrigerant, using the temperature differences between the evaporator inlet and outlet... Now I don't have to worry about discharging the stuff into the air (no reclaimer and nobody wants to reclaim HC's in their machines)... I can just fill until the temp probe shows equal temps between the inlet and outlet. It has something to do with a term called 'supercooling'...
So right now, I have immediate frost just past my orifice tube and that is what is called the 'phase change point' and the objective is now to move that 'phase change point' further into the evaporator by adding refrigerant. By adding refrigerant, the point can be moved further and further into the evaporate until it reaches the center of the evaporator. It is at that point that the inlet and the outlet temps should be equal.
You know, when I bought my new orifice tube, it looked like it was a maroon color and I asked him about it. He said that that is supposed to be the red that they use for the red color designation. :dunno Just maybe the orifice is brown or purple... I KNOW I don't have a obstruction at my orifice tube, so get that out of your mind...
If within 5 degrees of each other, stop! If inlet is 5 degrees warmer or more than the outlet, then reclaim some... If inlet is 5 degrees colder or more than the outlet, then add more refrigerant, little at a time and don't forget to wait ten minutes or so before you do anything else which will give the system time to equalize to the changes.
I'll bet you are holding your breath, waiting for me to get to my second mistake. It's probably the single, most occurring reason a lot of experimenters get discouraged and also could explain why I never got the temps I expected the first time.
I failed to account for the volume of my gauges! What I mean is your gauges can easily take up 4 ozs of refrigerant before it even starts to enter the system!!! That means that I would have needed 528.62 grams at the least and because of ES literature, I have reason to believe that the refrigerant may not be as good as advertised...
They have said that their stuff is 60% more efficient than R-12, whereas elsewhere, they say you only need 33% of the weight of the R-12 capacity. That is 415.5 grams, using 28.33 grams per oz. Then add in the 4 ozs needed for the hoses and there's 528.62 grams. But if the truth is 60% efficiency, then we need 498.6, then 4 ozs and we find that we need at least 611.92 grams and that amounts to just under 4 cans at 6 ozs each.
Better get 5 cans, because you have to purge the charging hose each time you connect it to a new can. You don't want to introduce any air or moisture into the system with any air that entered the charging hose during the time it was being transferred from the old can to the new can...
So, that's where I am and will be until I get more refrigerant, new R-12 gauges and an adapter to mate my new R-12 gauges to my can tap. Almost two weeks... This stuff (both the R-12 gauges and the Industrial ES-12) is not sold at the stores, so you can't just run out and buy what you need when you screw up. GET 5 cans if you are going to play this game!
Now for some A/C *****!!!
A pic of the orifice tube! Does it look red to you? I assure you that it is a 4-Seasons brand "red" orifice tube!!! :dunno
:yell: The Thingamob®!!! :love: LOL
itsacrazyasian
residentcrazyasian
boca raton, fl
Nothing ever fits like it should anymore. If you think that fit is bad, try some of the Asian import condesners. Holy SHEEET.
The charging hose i got with mine jug came with those adapters. they leaked! I tossed them out. Mine has all R12 fittings on it now. Charging this stuff by subcooling/superheat is tough. I will tell you that my accumulator is a solid chunk of ice when my ac is running for any length of time.
You do indeed have the correct RED orfice.
DaytonaBill
Yeah! I'd like to check that out! Thanks for the offer, LCAM!!!
DaytonaBill
Shouldn't the blue wires from the 87a posts (SS1 & SS2 relays) go to post 85 (parallel or in series) of the third relay? It looks to me that if the SS1 is cut (going into 3rd gear), then the SS2 trigger circuit would not be energized...
Or does post 35 of SS2 relay need a steady power supply?
I think (I probably just stuck my foot in my mouth...) either one would make it work. What do you think? I might be way off the track here, I've spent a good hour trying to wrap my mind around this :confused: and I've corrected myself a few times on stuff I missed the first time...
Please correct me if I'm wrong here...
LCAM, thanks for this idea...
kbeck
