Dsl_Dog_Treat
Gary, rocker arm retainer bolts are torqued to 20 ftlbs.
I'm back to fixing the Logger. I drove it 1.9 miles to work and back home today to listen and try to come to some conclusions. I did notice that the ailment gets worse as the engine gets warm. I have not gotten a "real" oil pressure gauge and can only look at my Ford "idiot stick". It pretty much stays in the center of its sweep. I know I have to get a gauge to see what is really going on.
I did more research tonight than wrenching but come back to a question I already posted: "Are the lifters 180 deg sensitive?" The oil passage runs along the outside of the lifters so I am wondering if the hole in the side needs to face it to get its proper amount of oil. It doesn't make sense to face it the other way but maybe I am missing something. I posted a question on Mahle/Clevite's web site, hopefully they will follow through. I found instructions that warn against a 180 install that would place the wrong side on the cam lobe but nothing about the clocking of them within the lifter bore. Looks like the intake may be coming back off
I got back to business in the shop today. So, take a look at this pic and tell me where the problem lies. I can not believe that the pushrod went right through the rocker arm. I'm guessing the guide is a bit tight on that valve, not the rest of the valvetrain as I was worried about. Now the question lies, did I harm the lobe, lifter, or pushrod? Tell me what you guys think. I call bs from a reman engine
Not a real common occurence on these engines, check for coil bind, put an oil pressure gauge on it, a mechanical one. If you dont already have it, and they are 7.3 rockers. But who knows where they are made, Send it back to promar, dont tell them the cam change or they will bs an excuse. get some new rockers from them. Also was the oil cooler on the new engine? If it was, they most likely washed the header in a dishwasher and the relief rusted and it will spike the pressure, saw it happen on "on da roads" truck.
