Good ways to add electrical connections?
fields_mj
Brazil, Indiana
I've got a new positive cable for the truck that I'll be installing in the next few weeks. I'd also like to be able to add additional electrical connections such as a medium size inverter down the road. Are there any simple mods that I can do to allow for that before I put in the new cable? Looking at the military style terminals, and the various options available for custom cables, it would appear like I just need to drill a hole through the middle terminal and run a flat head/low head/ or button head bolt up from the bottom. Should this work okay? Is there anything I should be aware of in advance? Should I just get alligator clips to go on the ends of my accessory cables instead? I'm not planning on having anything extra hooked up permanently. Only when I need it. Still seems like a ring terminal, stud, and wing nut would make for a better connection than an alligator clamp.
Thanks,
Mark
gatorman21218
Ashland VA
i would NOT use aligator clamps as those would vibrate off. I just use ring terminals and put them on the stud after the original nut, then put another nut on the stud, sandwiching the rings. I also have an aux fuse block fed from the hot side of the starter solenoid.
What ever you do make sure its fused.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
g31's are availible with screw top lugs. Go to amazon and search for battery terminal and there are millions of availible options. me myself I would not drill and tap a battery lug from the top just because I would fear the stud would be way easier to spark against and how many of us actually disconnect the neg bat terminal before wrenching on the truck. I would just use alligator clips for temporary connections where the truck will not be moving. they are availible in multiple different amp rating and are just plain easy.
madpogue
Madison, WI USA
All the main wiring for the truck is junctioned at the power-in terminal of the starter relay. That terminal just acts as a junction; the circuits don't go through the relay, of course. You can simply remove the nut, add a wire to that terminal and re-install the nut. I have a relayed headlight harness and a quick-disconnect for a trickle charger wired that way.
warhog
TN
That's my plan gatorman, an aux fusebox.Where did you mount yours? I'm not tackling the project any time soon, but just been in my mind that I am going to have to install one.
gatorman21218
Ashland VA
I mounted mine next to the coolant overflow tank.
Ive probably gone overboard with my wiring however. Its controlled chaos.
fields_mj
Brazil, Indiana
That sounds like a pretty good option. I think I'll go that route. Thanks for all the ideas!
crispy74
