Austin86250
double triple checked you hooked it up correctly if you haven't yet
Try tapping the relay that sits on top of the controller with something non-conductive (wood or plastic) and see if that helps. Maybe you got one with a bad relay that is already failing. If that goes bad, WTS won't light up and the plugs won't fire. The relay is the brown piece in the pic above, with the black piece on the bottom being the controller.I’ll check when I get home, but they definitely aren’t working. It takes a bit to start still. Also right before I replaced the plugs when I turned the key on the WTS would blink on then off and not come back on. It wouldn’t always do it when I turned the key either so idk
Yes the blue wire is for the WTS lamp. If it does not work, it does not affect the functionality of the glow plugs themselves. I would check the yellow main power wires first. Make sure you have 12v at the main stud, and make sure the connector that sits near the passenger side valve cover, that the pins haven't melted the connector casing and corrode.I’ve double checking it 10 times lol that’s why I’m so confused about it all. Nero- are you talking about the blue wire that goes directly to the WTS lamp?
Two thoughts.I replaced thisYou must be registered for see images attach
