Glow plug
cbwells
Lewiston Michigan usa
I put a monatary switch to work my glow plugs. When I push the switch shouldn't I be able to check the amount of voltage going to the glow plugs Thanks Curt
smolkin
Stuck inside Mobile
Mobile, AL
Do you mean using the factory cluster gauge? You should see a drop in voltage when the gps are on, as they pull some decent juice.
chevytaHOE5674
Ontonagon, Mi
Should be able to take the wires off the glow plugs and put the ( + ) end of your volt meter on the wire and the ( - ) on the block and read the voltage when the button is pushed.
