I put a monatary switch to work my glow plugs. When I push the switch shouldn't I be able to check the amount of voltage going to the glow plugs Thanks Curt
Should be able to take the wires off the glow plugs and put the ( + ) end of your volt meter on the wire and the ( - ) on the block and read the voltage when the button is pushed.
