need a lil advice on glow plug wiring I switched over to push button system seemed fool proof thanks to the tech forum on here every thing seems to work when i push the button relay clicks every thing seems fine but still hard to start thinking i had some bad glow plugs started checking found i have 11 volts on wire feeding glow plug as long as the switch is on even if the button is not mashed thats not right is it ? also removed 2 1/2 glowplugs 1 covered in oil and 1 swelled up left it for now ran outta day light. any advice is well appreciated
