Well, I searched and couldn't find exactly what I was looking for so here goes:
WTS light stays on about 6-8 seconds. Tested the voltage at the GP's = .01v
, yep, thats right 1/100 of a volt. The yellow wire going into the controller ar at 12.65v. All else seems to work like its supposed to, The terminal exiting the controller to the GP's is at .01v.
Guess the controller is bad? If it could be anything I am missing (still need to doublecheck the ground), let me know. If it is, is there a good brand? Or one(s) to avoid?
Thanks
, yep, thats right 1/100 of a volt. The yellow wire going into the controller ar at 12.65v. All else seems to work like its supposed to, The terminal exiting the controller to the GP's is at .01v.Guess the controller is bad? If it could be anything I am missing (still need to doublecheck the ground), let me know. If it is, is there a good brand? Or one(s) to avoid?
Thanks
, will check better this morning). Anyway it is quite a bit better than before. I needed to run the gp's 2 cycles on colder mornings before, shouldn't have to now
