KodiakForge
It should be wired like this:
Your push button ground needs to be connected to the post with the white wire. If you wire it exactly like this picture, and add the push button to the white wire post (in addition to the one from the controller) the controller can still operate the plugs, or you can over ride it with the button. This is how I had my 92 (previous truck) and will my 88 when I get to all the wiring.
I didn't move the WTS wire, since I know if I was pushing the button, the plugs are on. Not sure if the WTS wire being on the ground is the problem. Also, are the 2 greens going to the same place on both ends, or are you pulling power off the constant hot for something else?
I fought with mine, but this picture saved me... I wired it like that, and added the ground push button, and I was golden.
Right now, my "glow plugs" are in a spray can on the front seat....
the 2 green wires are my constant hots to replace the burned out yellow ones that come off starter solenoid on passenger fender (with fusible links between starter solenoid and glow plug relay) they melted at connector. ill eliminate WTS light just to see. I have tried the bypass including the white, red, yellow and green wires from controller so it could work as well as be overridden but what ive found is that whenever the white wire is connected to small post my controller just clicks and clicks cycling on/off constantly but if its eliminated everything seemingly cycles as it should minus output power.
just to clarify for me this bypass can and should in theory work for me still if i disconnect all controller wires of every color and wire it exactly as the photo you sent to me? im thinking part of my issue is the controller is bad but thats kinda the reason for bypassing it i suppose.
