dieselrunner
At least I think thats the answer.
Problem is the glowplug system (somewhere along the line) does not function properly regularly. When the ignition is turned to "ON", normally the glowplug system should begine to heat and cycle. Well this only happen about %10 of the time, I can tell this by watching the volt meter on the dash. Im aware its the stock "idiot light" guage, but differences can still be seen. Times when the system doesnt work, is when the volt meter shows a reading in the "normal" range and no draw on the batteries for the glowplugs (this is confirmned with a No Start). Times when the system does work the guage reads lower on the scale indicating a draw on the batteries (confirmned with Start). Had this problem for about a year, but it is getting worse. Which leads me to belive it is a bad grounding somewhere. So advice is needed as to where I should be looking for the culprit. I am aware of the ground for the Controller/Relay, behind the intake, and will be checking there. Is there anyone else with this problem or with some other common failing grounds/connections?
Thank You in advance.
