gear oil?
NJGearhead666
New Jersey
so how much rear gear oil will my 12 bolt rear take? I got a new cover today and wanna know about how much oil the rear takes with the stock cover?
dakotajeep
Patrolling
TN/ND
Approximate Lubricant Capacity (In-Vehicle Repair)(a) (b)
Vehicle F-250, F-350 Regular & Chassis CAB, F-250/350 H.D.
Axle 10.25-Inch Ring Gear
U.S. Pints 6.5(c) (d)
Imperial Pints 5.4
Liters 3.0
(a) - Ford design conventional axles use Rear Axle Lubricant XY-90-QL or -KL (ESP-M2C154-A) or equivalent.
(b) - Service refill capacities are determined by filling the axle with the specified lubricant to the bottom of the filler hole with the vehicle in running position.
(c) - Plus 8 oz. (U.S. measure) additive friction modifier, C8AZ-19B546-A (EST-M2C118-A) or equivalent for limited-slip applications.
(d) - Rear axle lube quantities must be replaced every 100,000 miles (160 000 km) or if the axle has been submerged in water. Otherwise, the lube should not be checked or changed unless a leak is suspected or repair required.
Note: 6.5 pints of lubricant is the fill specification when the axle is installed in the vehicle. If the axle is out of the vehicle, fill with 7.5 pints of specified lubricant.
This is a post by cdnsarguy on TheDieselStop. He's a reliable source!
Thad
FWIW, Use synthetics. I did and I believe it helped me increase my mpg. Yes, they cost more but to have been worth it!!!!
If you tow, I would acquire differential that allows more fluid capacity.
FordGuy100
Silverton, OR
Yup, sounds about right to me. I would just go on the safe side and get a gallon container.
I just ordered Amsoil 75w-90 synthetic gear oil.....cost me around $35 a gallon, and got 2 gallons for the front and rear diffs. Talk to RLDSL about Amsoil if you want ;Sweet
dakotajeep
Patrolling
TN/ND
You'll want to run 75-140 in the rear differential though, if its a 10.25 Sterling. 75-90 is right for the Dana 60.
Thad
FordGuy100
Silverton, OR
I have a Dana 70 ;Sweet if you were reffering to me.
I'm going for fuel economy, the lighter oil will help. Also, worst case scenerio is that my rear end seizes or something and I pick up a used Sterling axle for $200 complete, cause they are everywhere around here.
hesutton
The Anti-Anderson
Bowling Green, KY
Once you've filled the differential will oil, be sure to park the truck on an incline with one wheel higher than the pumkin. Then, turn the truck around and get the opposite wheel higher than the pumkin. You need to get lube down the axle tubes on both sides. That's the only lube those bearing see. Once you done this, recheck the fluid level and add a bit more if needed.
Heath
tractorman86
Buckeye, AZ
ah ha someone has seen wheel bearings burn up right after an oil change huh?:D i've only heard nevert seen. a forklift works very well for this
Actually that shouldn't happen, unless you've pulled your axle shafts. The oil in the hub will stay there when you drain the pumpkin. The bigger mistake is to have pulled you axle shafts, and not refilled your pumpking and done what Heath mentions. If your changing lubricants and are concerned about mixing types, then you should intentionally drain your hubs also.
