Calling all turbo gurus.
What's the trick for getting the new oil rings loaded back into the housing without screwing them up?
Got them onto the shaft and the thrust collar ok, but when trying to stuff the exhaust side in I managed to screw that one up
. Got to run by a turbo shop tomorrow and pickup another ring.
The housing is tapered a bit , I had it all greased up with lubriplate, looked like it should stuff in, obviously, I was wrong.
Also, does that exhaust side ring go in the grove closest to the wheel? It's got the flat cut in the bottom so I assume that's the one. Should have taken pictures
Thanks--------Robert
. Got to run by a turbo shop tomorrow and pickup another ring.The housing is tapered a bit , I had it all greased up with lubriplate, looked like it should stuff in, obviously, I was wrong.
