I wanted to to upgrade my headlights with relays and an H4 conversion. Got some Cibie reflectors and Phillips bulbs but debated which way to go for relays. Ended up getting a Bussmann 15303-2-2-4 RTMR. I like how tiny it is yet fits 5 relays and 10 fuses, plenty of room to add more later. Almost done wiring that up, probably finish in the morning as I just need to run the wires to drivers side headlight,put the plug on that end, and put the rest back together. Biggest part of this was figuring out where to put in, and relocating everything else to be more compact and cleaning up 30 years of previous owners hackjobs. I chose to install on the passenger inner fender metal plate that much of the original wiring mounts to.
Originally looked like this:
I had previously cleaned up the wiring a little after the 3g install and it looked like this:
I pulled the inner fender mounting plate, blasted, painted, and rearranged some things:
Almost done the wiring. Excuse the messy bench, too many projects are one time...
Hopefully I'll have finished pictures tomorrow.
