Why does it take 25 min to fuel the tanks on this truck?
There may be a difference in the plumbing of your 1990 tanks and my 1985.
When I first got my truck, way back in the good old days, it would puke fuel out and all over me when filling; it took forever to get a few gallons in.
I monkeyed with the vent-hose that rides up the filler-neck and it helped a VERY LITTLE.
I crawled underneath and examined the tanks and found that the tanks have a SEPERATE GENUINE VENT HOSE, 7/16 I.D., shoved into the tank through a rubber grommet and protuding about two inches into the tank.
Attached to the ends of these vent-hoses were plastic roll-over-protection loose-ball valves, with more air restriction than a kid's toy whistle.
I removed those plastic obstructions and threw them in the trash, covering the hose-ends with little window-screen socks.
After that little modification, it would nearly suck the hat off my head and into the tank, the fuel would go in so fast; I could even use the rapid-flow big-truck pumps and not spill a drop.
A couple years ago, I routed all new 1/2" I.D. vent-hose, TEE-ing the vent-hoses of all three tanks together, and having it terminate up high and dry at the top of the head-rack in a down-ward pointing horse-shoe bend.
I did this because before, due to heat-expansion, sometimes a very full tank would expand and push fuel out the vent; all TEE-ed together and having a lot more hose to fill, the expanded fuel never makes it outside the system, draining itself back into whichever tank has room for it.
