fuel system w/ frame rail mounted filters.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
IDIoit.. feel you on the location argument..... been crawling around under my project arguing with myself about ease of service vs vulnerability vs ease of plumbing for a few days .
Clb
Another old truck
nannyfornia
Thank gawd this **** is pavement pounder duty...
Flat belly in my world (rockcrawling) would kill half this forum...
Clb
Another old truck
nannyfornia
Orifice idea is the ****, almost every industrial diesel does this, it works. There is afancy valve in your box o stuff coming, maybe it can work.
WINNER!
orfice deal...
been thinking about this
only need a 1 way check valve in my mind, so air don't feed back to the filter.
fed to the top of the tank..
this about the jist of it?
the tank is the only thing holding me back from throwin the bed back on
I have a tube style sender on its way,
going to do a fast fill mod along with a -4 an orfice connection.
Clb
Another old truck
nannyfornia
Food for thought on that...
I think a chest mounted to the floor of the bed could do double duty.
Hinge the floor for access under the deck, close floor and fill with tools..
typ4
Newberg,OR
So if you're not running a filter inside the engine compartment I would definitely incorporate a fitting at the top somewhere of the engine with an orifice in it returning to the return block at the back of the engine or the return line wherever you don't want that excess to go through the nipples and caps. Or you could do it at the last filter if they're both mattered on the frame just a tiny tiny orifice going back into the tank or even the return to the tank and it will always keep the air out of the system. It's basically copying the air eliminators from the fuel trucks that we dealt with for the helicopter company they don't want are going into the fast fill dry break because it surges The fill line for the helicopter, of course wer'e talking 2in line here but still the principle is the same.
chillman88
Central NY
IDIoit, definitely want to see how you access that stuff through the bed.
That's the main reason I haven't really considered mounting batteries under the bed on mine. Although honestly, those worries are quite a bit different between a toy and a work truck. And also between clean-metal-cali and rust belt LOL
Clb
Another old truck
nannyfornia
Add a disco. Switch in the wheelwell as antitheft deterrant
yes sir. but going behind the 40/console/40 seat. kinda like the manchhero.
thanks for the help folks. ill update again when I get the fuel block in.
prolly be a few weeks.
but the tanks done with orfice port on the tank.
fast fill mod.
and a tube style sender with pick up
Chemgrad
NC
What size pump are you running and what turbos?
kbeck
