Fuel Pressure's on a 6.0
OLD93
Dennis
Apple Valley, MN
any idea what fuel pressure a 6.0 is normally?
If a gauge was installed on top of the engine fuel filter could that be used to determine when the filters need changing?
thanks!!
HeavyAssault
Wicked Weasel Lover
Central VA; Hampton Roads
Normal range is 45-55PSI at the upper filter housing. Since the by-pass should be over 55PSI your readings will fluctuate depending on the fuel system performance. I doubt you would ever find a clogged filter causing a drop in fuel PSI. More often the HFCM will loose output and cause lower than suggested PSI readings. There is an updated fuel pressure spring kit from Ford and International that gives an slight increase in normal PSI at the housing. Additionally you can add an AirDog system to help filter out air, water and debris while providing a steady source of fuel to the HFCM. There are more options as well with the ADII so if you have more questions just post up.
bismic1
Texas
The updated spring is a highly recommended addition. It bumps you up to the low 60's at idle. WOT should be in the mid 50's.
Anything below 45 psig will reduce the life of your injectors.
Loganm223
