Garbage_Mechan
Garbage Mechanic
The explination of how the pump works is correct. However they don't shut off because we have an orfice returning fuel to the tank so there is flow even if there is no use.
Think of the pulse pump like this:
A bicycle pump that you pull up on the pump handle and it is spring return. the spring force is what regulates the output pressure; when the handle is all the way down a little bell rings to tell you to pull it up again. If there is no flow (head pressure) then the pump handle will reach the bottom of it's stroke so you don't pull up again. If there is flow then the handle will lower at the required rate until the little bell rings.
The only difference in the electric pump is that the solenoid contacts are closed when the piston bottoms out, triggering a new cycle. The really nice thing about this is that there is only power used when fuel is needed, and the higher the fuel needs, the faster the pulses. The electric 'whine in the tank' style is on 100% of the time.
The pulse pumps (probably diaphragm) are positive displacement with efficient check balls; that is why they are self priming. The motor type probably use a vane and don't create vacuum well.
