Garbage_Mechan
Garbage Mechanic
Of course some thought would have to be put in to the flow pattern to be sure the return flow off the injectors was not pressureized.
I tried this set up on the 86 because I didn't like the pressure dropping to 2 psi at WOT. I used a Walbro pump, and a regulator. No problem with the return flow. I did have two observations: Anyone who thinks the fuel pressure doesn't affect the timing better re read how the cold timing advance works.....by increasing case pressure. I know that if I ran the fuel pressure up, the engine sound and performance changed. 15 psi fuel pressure was fun but I knew better and tried it just for a few minutes. The big downside to the regulated system where the flow is tank>pump>regulator>filter >IP is that it won't prime. With the Walbro or Carrier (Facet duralift) pulse type electric pump, it will easily prime and get running again if you forget to change tanks or otherwise get massive air in the system. With the Walbro powrstroke style fuel pump, it wouldn't prime without taking something loose. It didn't seem to help performance any even though fuel pressure was rock steady any RPM or throttle setting. A couple of other observations. The more fuel we move but don't use, the more heat and aireation we create, both enemys of effecient injection.
I was going to go the route of the SD 7.3L electric pump I got from the salvage yard, knowing I would need to run a dedicated regulated return. I have been reconsidering lately something in the Facet line up.
Second question: Why not make it a "regulated return" set up so a regulator set at 8psi is installed at the return flow outlet of the pump. Fuel would still flow through the pump and back to tank but only the volume needed to keep it at 8 psi. More return flow at idle, less at WOT. It works on the 7.3 Powerstroke, yes at 60 psi but same concept. And the later 7.3's upgrade to a regulated return to improve performance. The only thing that could go wrong would be if there were not enough return flow to cool and lube the pump. Thoughts?
You want to regulate to 5 PSI. That is the spec to which Stanadyne designed the pumps, and to which the industry calibrates. It is a fact that higher inlet pressures will start to screw with the timing on the pump, and invalidate your calibration.
Are you running dual tanks? If so, how will you switch return flow on your dedicated return to the proper tank? I think one reason many shy away from a higher pressure pump regulated down is the complexity of the regulator return. If you run it through the stock return you can have problems with excessive pressure. If you create a dedicated return you have to be able to switch tanks so you don't end up overflowing one tank. You also need to make sure the regulator can both handle the 70psi or higher, and allow enough flow at the low pressure you're setting it at.
As far as the injection pumps, like Mel said they are commonly calibrated with 5psi feed, however you can always specify to your pump builder if you'd prefer it built with a different spec. It will work ok with slight pressure deviation up or down, but it will affect the calibration the further you go away from 5 psi.
