my firend has a 1996 powerstroke, i have to put a new furel pressure regulator on it, but i dont remember taking a spring out like on my 02, just a plastic ball? is thers one?
yes there is a spring.on the drivers side of the filter housing is the FPR.2 10MM bolts hold it on.but on the side of the FPR you will see a brass nut.inside that nut is the spring and valve.i believe its a 19MM nut.
oh, ok so if u pull the regulater off, the spring wont be there, just the screen right? ok cus i couldnt remember taking a spring off, so i thought i lost it, but i never took the plug out
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
