maverick350
When I first put my truck together, I put a low pressure electric fuel pump in line on the frame rail along with the mechanical pump. using the electric for priming purposes for the most part.
I recently replaced the mechanical with a faucet dura-lift, and put in a fuel pressure gauge.
Now here's where it gets interesting. With the small electric pump on the frame rail, maybe 1.5 psi. the 0-30 psi gauge barely twitched.
Turning on the dura-lift on the fender well, 7 psi.
Turning both pumps on, 10 psi.
Turning the engine on with just the dura lift, pressure drops to 4psi.
Under a load, climbing a hill, pressure drops to zero. Truck runs great.
I need to check my gauge with another to be sure, but I'm surprised to see this much of a pressure variation. Is this normal?
