BigRigTech
Diesel junky
Does anyone have the part numbers from International for the o-rings on the IP supply line from the filter head for my 1991 7.3??? I have a fuel leak at my IP, it's not pouring out but it's making my valley pan quite wet. It's coming from the rear of the IP I think so I'm going to try those O-rings first. I called my local Ford dealers - none have any stock and IH could not do anything for me unless I brought them one for a sample.
....Are there any other common leaks on the rear of the IP? The injector lines are all tight and the truck runs fine. It takes a tiny bit longer to start than it used to in the morning - I think it's losing it's prime a little over night.
...Plus he's got connections at IH so maybe I can get them without the usual song and dance.
...Anyway this is what I was going to suggest. The lines get cracks and pinholes and spit fuel everywhere! No matter how much you tighten them down they will still leak if they are cracked. It's hard to tell exactly where it's coming from sometimes. I just replaced a line on Sunday and I couldn't even see the crack under the nut where it connects to the injector but it was definately there. Even after I got it off I still couldn't find the hole. I also had my feed line for the IP grow a crack and I replaced the #7 line before I realized that it was the line feeding the pump. Look around real good with a flashlight you'll probably find that you have a bad line.
