saltbranch
89' 7.3
The housing where you screw the filter on to. There is a wire/connection on the top and one that comes in from the side. What do they do? The connection on the top starting leaking. I was able to pry off the wire connector, which pretty much detroyed the connector and use some sealant to seal the leak so I could make the 100 mile drive home. When I get a new filter head or whatever its called does this wire need to be hooked back up, if so think Ford will have the connector?
Thanks
Thanks
