Fuel additives?
fields_mj
Brazil, Indiana
I've noticed that a lot of guys are using fuel additives to make up for the lack of lubricant's in the diesel we buy at the pump. My question is two fold.
Question 1 - What's the most economical additive to use. By economical, I don't mean cheap and worthless. I mean useful and then inexpensive.
Question 2 - I've heard a lot of guys tell me that I can burn almost anything in my 7.3L IDI. From kerosene to used motor oil and SVO. Can I take my used motor oil, run it through a filter, and use that as a fuel additive? I don't really care to try to burn used motor oil as a source of fuel, but I figured if I'm going to have to bottle it all back up and take it down to be recycled, why not just pour it into a 5 micron sock filter and make some use out of it?
Just curious,
Mark
Somewhere there is a chart that shows which lubricitity additive was the best. Wish I could put my finger on it for you right now, but I don't have it. Generally speaking, there is no good cheap additive.
hesutton
The Anti-Anderson
Bowling Green, KY
I would recommend only using a product that was specifically designed to be used as a lubricant in diesel fuel. Staynadyne would be my first choice but it is not easy to find around here. I typically use a double dose of Power Service with each fill up.
Heath
Popeye2347
Winchester, Illinois
Staynadyne is only slightly worse on our IP than TC-W3 on the above chart. Probably would never notice the difference unless in a lab.
YMMV
