http://dieselpowerman.tripod.com/Front Axle Tech/Front Axle Tech.htm
Here's a link I found. Check it out and see what you guys think if it'll work.
NOPE that's a solid axle dodge...seems we may have an easier solution according too the previous poster...PakRat239
Really we should have determined the model of axle before the advice... as it is important and there are subtle differences between them....
I'm not sure I haven't seen a 44...chicken wing if it's got that same hole as the 50...I'll look on my Bronco later..
.I actually did not know that one could do the seal without pulling the pumpkin out on the 50TTB, interesting.
Thats one reason I love this site...so much to learn!
As for pulling the axle on TTB or a D60, yes remove hub, remove spindle (if you can, known to be nasty), withdraw axle, (now is good time to replace Ujoints too...and repack wheel bearings and replace inner WB seals...
and if you are in ONE side, it would be wise to do the other at the same time(new axle seal, repack wb and seal and maybe ujoints too! Then you won't be doing this twice...once now and once later down the road, OR JUST ALL AT ONCE...your choice!
Breather is a hose that connects to top of diff (cant recall exactly where on 44/50 but leads upwards to cross member and is clipped up there, there should be a plastic cap on it. It has three wings that stick into the hose allowing air to escape and enter...AKA diff breath...if it's plugged and the oil heats up...hot air forces oil out seals as it expands...
Pull the hose off the diff, and attempt to blow through it...watch out gear oil tastes nasty...but it's gotta be done....if you can blow through it...yer golden
Gavin the PUMPKIN is the portion of the front diff that unbolts from the TTB swing arm/chicken wing and you can take into the shop and work on the carrier...Pumpkin is a generic term for a removable diff...like Toyota/Ford 9" Dana 44/55 TTB etc
This pic shows the TTB swing arm/diff cover...the PUMPKIN is what bolts to the other side...it's the big cast iron part that axles come out of and the pinion sticks out that the drive shaft attaches too.
