It will be the same width. It is hard to tell for sure though from the pictures. You would also have to regear it to match your 3.55s or regear your rear to match the 4.10s.
Thats what I thought at first but It is actually sitting upside down..... I think. I did some reserch and the vans with the leaf springs had the springs mounted underneath the axle......at least from what I can see. I am not sure if I can make it work or not. I am just exploring an option right now.
cant help much but i actaully ran into Quigley at a buffet, they are right by me.
it says its a driverside drop in the description, if you could count the cover bolts you would know if it was a Dana 44 or 60. you cant really compare the stock suspension info to what this is since they make a bunch of changes.
