Idiabuse, we understand you are trying to push for everyone to use amsoil products and bypass oil filtration systems. You have made your point very clear many other times before in different threads. Leave the people alone who choose not to use amsoil and I'm sure others would appreciate if you didn't critique others choices all the time. This is not other vehicle forums where every thread is a ******* match because of the people who choose to go too far to prove their point or theory. Don't take this the wrong way.
Hydro... Please don't think I'm throwing you under the bus. My opinnion is this.. I do not feel idiabuse is pushing the Amsoil or the bypass down anyones throat here. Reading that I originally posted about I would feel I'm the one asking the question about why we all are not running a bypass filter.. Can it hurt something in the engine... Nope... If installed correctly will it help anything in the engine... Of course it will. Is the average person able to install it correctly.. I hope so. I read your posts about the idea that a bypass system is just another possibility for engine failure "IF" and thats the biggest little word in the world. If a hose broke and you lost all the engine oil. Well thats easily solved by running the same oil lines that Banks does on ALL of their idi turbo supplys. AN fitting on both ends.. There. Your well thought out oil loss issue solved. Clearly this is an internet forum where opinnions rule the waves. The interesting thing about oil is it never wears out. It just gets dirty because its supposed to carry away the dirt and cool the parts besides lube them. Actually water is the only thing on earth that can't be ruined by use. Can you burn it... Nope. It just turns to steam and comes back clean as day one. Everything else is used up when its used. Oil becomes carbon and soot.. Gas becomes all kinds of crap in the air we breath.. Coal.. Well lets not go there. Nuclear is clean but the waste rods will need to be cooled for at least 8 years. Most times its closer to 10 years in the spent fuel pools. Then its goes into dry cast storage containers where it will maintain 500 degrees for 10,000 years. I worked with the nuclear field for a few years.... I may not know everything.. But I know something about alot of things. Its my opinnion we should be running a bypass filter on our idi engines. Nobody is making any new blocks. Look at the chevy blocks industry that sprang up... You can get any block in the after market thats better built than the oem blocks. Thats a good thing too...
. Just stating the obvious bud.
