Found this old dude
austin92
Brazil. IN
My truck had ac and a wide radiator. Is that where the optional part came in?
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
In the bullnose trucks 80-86, you had 3 HVAC options:
Heat only
Factory A/C
Dealer Installed A/C
A heat only truck did not have vents in the dash, only the floor and defrost vents.
A Factory A/C truck had vents in the dash along with the floor and defrosters. These were 3 entire different dashes.
A Dealer Installed A/C most of the time was a "self contained" unit that had controls for the A/C built into it, that mounted under that dash and provided only A/C. The heat still ran through the floor and defroster.
Starting with the bricknose trucks, they all had vents in the dash, with A/C or not.
Normally the non A/C trucks had the short wide radiator. The Factory A/C truck had the tall narrow radiator.
austin92
Brazil. IN
Heat only
Factory A/C
My truck has dash vents, ac controls in not under the dash with the heat controls, short wide radiator, and standard output heater core. None of that seams like a standard combination. Maybe my truck is just an example of how you could order what ever you wanted back then, no “packages”. My condenser and pump has been removed and lines to the evaporator cut. I’d like to restore all that but my vents are stuck on defrost. Still love the truck lol
Conky
Manitoba, Canada
I don't know. The auto is better for building boost(and shifting without losing any) but /man/ do they suck power.
Your living in the past man, when an auto is all locked up in direct drive all your loss is a pump. ie not much!
I think you will find that all wide radiators will have the two piece fan shrouds.Kind of a nice idea. The one piece is not fun to work with...
None of the automatics I have driven with these engines takes advantage of the low end grunt these engines have. The rpms don't need to go as high as they do to take off, though I suppose that does work better with a turbo on it.
tke395
