sandrow
Checked vacuum lines they are new, checked the vacuum pump behind the master cylinder steady suction very strong and even. I'm stumped whats next? what else could it be symptom is intermittent power brakes
will make world of differanceit was 20 lbs the first check shut it down restarted and it was 10 checked again and it was 20. the mechanic suggested replacing the vac pump. sound right????????
