Diesel_brad
Dunce
This is in an old Leroi compressor. It used to run 5 years ago. After messing w it for about a half hour while charging battery i tried to turn it over by the fan. Well that didnt work , so i put a braker bar on the crank bolt. NOPE, Seized. Then the oil was over full, noticed water on the tip of the dip stick. Cracked drain plug and i get coolant, I figure at least 2 quarts.
So it would make since to me that the block is cracked, pistons are seized, so i need and engine. Anyone have a clue where i could find one? I checked craigslist and ebay but nothin
Or has anyone evre run a air compressor w an 8N? off the PTO
