******* for the engine
redneckaggie
rebel w/o a cause
angleton/stephenville tx
so I'm tryin to get a propane setup together what switch should I use for the shutoff to run inside the cab and is this a burst method or a constant flow method.
redneckaggie
rebel w/o a cause
I have found that article but just have a few questions. First let me tell you what I have.
I have the fog tube for the intake
I have 10 ft of lines but its 3/8
I have the regulator
I have a bunch of different fittings and stuff like that
I dont have the hobbs switch or the micro switch where would you get them
Propane is generally only used when extra power is needed. If you ran it all the time, you'd run out of gas pretty quick.
redneckaggie
rebel w/o a cause
here is what ive come up with for micro switches which one would be best
sootman73
Wauseon, OH
did you search on radio shack or tiger direct? they often carry stuff like that. just have to search around. make sure you know what kind of micro switch you are looking for. like amperage, voltage, and style.
Optikalillushun
Coal Region, Pa
u are correct, blow! hehe
aggie, i assume u are N/A? there was some chit chat on FTE about using a three stage set up to act as a progressive system...i think cheaperjeeper was the one who started talking about it.
poolguy
Slippery when wet
Gulf Coast
About how much of an increase (in power) would you realize?
Does it matter if I'm running a turbo? (of course I am)
What does it do to the EGT's?
Since everthing has a cost, whats the down side?
Chuck
sassyrel
iowa
down side????? you inject too much to a diesel for too long--piston meltdown. a lot of farmers experienced this years ago when they found out what it would do!!!!
FordGuy100
Silverton, OR
Yeah, I would say you would notice a pretty noticable increase in power. EGT's, I've heard from some they go up, and others they go down, I dont really know. Downside, you have to pay more at the pump, or like stated you melt it down.
SixFourShanks08
