redneckaggie
rebel w/o a cause
so I'm tryin to get a propane setup together what switch should I use for the shutoff to run inside the cab and is this a burst method or a constant flow method.
"i cant feel my face man"...what movie is that from? heh
Propane is generally only used when extra power is needed. If you ran it all the time, you'd run out of gas pretty quick.
