69oiler
I don't feel tardy
well if you want 4x4 i'd suggest an '86-94 f350 because of the dana 60 solid front axle. the f250 4x4s of that vintage have an ifs system that is tough and works well but i can be rough on tires. also, 85 and earlier f350 4x4 trucks had the ifs.
86 or 87 would be a safer buy due to the fact that the 6.9 from those years is less prone to cavitation than the 7.3 from later years, while also benefitting from upgrades over the earlier 6.9s
if you want an OD trans you will have to get an 87 or 88 or newer, the older ones had a direct drive top gear.
or you could go with a dodge cummins, that motor is a powerhouse but i think the ford chassis is better than the dodge.
i dunno about the GM diesels, they have a following of thier own but i don't think their diesels are in the same league as the ford and dodge
or if you wanna spend a little more i have a '99 PSD for sale..
