crash-harris
Breaker! Breaker!
So let me start this story...my 1990 gasser (Bruiser) that began life as a 2wd 300 powered 5 speed went through 12 owners and a lot of abuse before me. I converted it to 4x4 and saved the inline sixer and have started to near the 600K mark with only a top end rebuild (really only needed to readjust loose rockers, but swapped in guideplates, hardened pushrods, steel timing gears and chebby rockers). Swapped in a 1 ton rear end and have the matching D60 waiting for the front, plus other repairs that I haven't been able to get too. She started telling me that at least new rings are needed as I was pulling a 16' flatbed and stayed smelling the blowby. Since I work second shifts building KW trucks, I don't really have the time to get everything done and already have a bronco that needs a floor and put back together for the fiance, I decided it was finally time to get my next truck. Sounds like a good excuse to get a diesel and fill up the driveway, right? Anyway, enter the Enterprise D. 1990 F350, crew cab, long bed, diesel, dually, overhauled by Western Hauler. Had about 165K on it when I picked it up a few weeks ago on the other side of the state, but has a Jasper 7.3L IDI with unknown miles on it and a recently rebuilt ZF5 and oil cooler...and not the greatest paint job when you get up close (some runs, no clear coat).
I'll take a pick break.
Under the hood, there are some things that are obviously missing. Cruise control vacuum canister is gone. WIF light is on and the fuel filter is a Wix one piece, so there is no bottom housing to put a new sensor into at the moment. I have new ZD9 glow plugs that are ready to go in. Pull one of the old ones and found that they are indeed freggin' Autolites. #5 was fine, just burnt, so I hope they are all like that.
I will post again here this evening starting all of my questions and posting pics of the top side of the engine. It's time to go dig post holes while we have the weather. Did I mention we're fencing in our yard on top of all the other work that needs done?
