65sixbanger
I pulled the blown motor out of mine, the motor out of the truck at the junkyard, installed mine fully dreesed, pulled it again and put it back with the rad support on. You get pretty good at it
I have never pulled the front clip before. I always did it the hard way. The first time I did it I pulled the grill & radiator support because my hoist wouldn't go high enough. That was alot of work. When you pull the whole front clip, do you leave all the Peripheral Paraphernalia attached to the inner fenders and just unplug or disconnect it all and do you leave the hood on the clip or take it off first.
Javier - Thanks a lot. Nice thread. It's been several years since I stuffed an IDI and I really appreciated the refresher. I did precisely what you did minus the hood. But I didn't have the Turbo to deal with.
Mel - I'm game for the full clip pull, but I'm still wondering whether to disconnect the Peripherals from the Cab or from the Clip or half and half. I believe I am going to attempt to "lay off" the A/C Compressor and Condenser back over onto the windshield / cowl area while the system is closed.. I just got it charged with R-12 last season.
i know you'll argue with me about it, but others need to read it before they try it. flipping the ring gear on these motors is a bad idea due to the fact the teeth are bevel cut on the starter side. Starter Bendix gears have a tough enough time meshing without clashing, so a straight cut gear is going to make things a little more dicey. I'll post pics later so show the difference in the front and back sides of the ring gear.Hey thanks for the heads up I had to remove the ring gear with a torch and reversed it, so I'm good for some time, but I hear ya!
I had that whole deal balanced, so hopefully the last I will fool with that.
My starter is the mini starter and works great with my giant battery and cable wire.
Javier
