fan clutch and A/C
budtoh3zo
Little Smoky, Alberta
Is the clutch on the fan for a 1994 electronic controlled? The reason i ask is when my A/C is on the fan kicks in alot more. Even if i idle it for 10 min and go again the fan is engaged although the motor cooled off. Thanks
DmaxEter
Meet Mike Hawk
Olive Branch MS
No, Its just the extra heat from the AC condensor making the clutch come on more probably. It has a bimetalic coil on the front of the clutch and it is sensitive to heat. It expands and contracts with heat allowing the veins in the clutch to either get oil supply and lock up or not and free spin.When the AC is on you have the added heat of the condensor up front heating things up and its causing the clutch to cycle mor regular. God forbid they ever put an electronic viscous fan clutch on the trucks :puke:
jlayne
Bondo Bandito
Milledgeville, GA
how many folks have had to replace their fan clutch? just curious...
mine seems to be working fine at 110K but i have a jeep that i ditched the fan clutch all together after i had replaced about 3 fan clutches, after a short horrible experience with electric fans I put in a aluminum spacer and flex fan in it that has worked flawlessly .. needless to say i don't have much faith in a fan clutch of any type or electric fan unless they are on a race car, if flex a lite ever makes a reverse flex fan big enough for a PSD i'll be putting one on mine that day
hheynow
the misanthrope
SF Bay Area
Mine is original but I'm wondering what are the signs that a fan clutch is going south? My truck seems to be running a bit hotter these days (used to run at N but now runs between R and M). There is no leaking/weeping from my water pump and my t-stat is new.
jlayne
Bondo Bandito
Milledgeville, GA
when my jeep fan clutch went bad it would get hotter than a preachers ****** (overheat) at a stop light or if it sat at idle but as soon as your got it moving down the road would cool off (it was getting airflow to the radiator) to normal temps... i'm assuming a powerstroke would do the same thing... although you wouldn't know untill it was REALLY hot thanks to the stock idot gauges
jlayne
Bondo Bandito
Milledgeville, GA
budtoh3zo said:
A diesel gets hot when u drive it and cools off when u idle most times
true as does most vehicles, but its not supposed to boil over when it idles if its operating correctly :thumbsup:
wftree
Western New York
Having mine replace as we speak 150,000 miles My fan only comes on while towing, it never comes on when I am empty.
While towing mine would engage and disengage every 10 seconds when she got hot. Jus would not stay locked up.
OEM $292
NAPA $272
Went with OEM
