bigpanda16
Soon, I have read stacks here and lurked around while owning my 94 turbo idi for the last 3 years. I was towing my racecar last Thursday night on a four hour drive about half way there and we pulled into a rest area and as I braked we smelled raw fuel real strong. The valley had filled up and the no.1 injector Hardline began to drip Atpumped ump output every pump rotation and also let air in. Immediately the truck started skipping. I yanked the line and the 22 or 30 degree or whatever male seat looks like it has a groove in it. Wouldn't seal, it was initially a little loose. I am wondering if the injector failed shut to cause the sudden buildup of pressure? I have one spare rebuilt g-code I got from Midwest fuel injection I was going to put in place of the possible failed one. The truck was doing incredibly well running around 12,500 lbs all told, passing 18 wheelers and some cars running around 75mph... It was building heat no problems and accelerating up hills. Then bam, air intrusion and heavy leaking. There was no indication except a flutter I felt maybe 2 or 3 hills before the rest area.
Luckily I got the truck on a hot-shot wrecker home compliments of Atlanta triple A with only a few miles of overage. What I am wondering is would it be worth it to step up to Delphi bb injectors over my g's? I am tactically out of work and my truck is sitting in front of granny's house dead in the water. So I need to source used hardlines and install my lone backup injector. But long term, would i be better off? Do you need to retard the pump timing slightly to allow for the earlier opening at 19,000 psi vs 23,000 or whatever the difference is on the injector opening timing. My truck is timed by ear and really sings now that I have replaced my fuel filters.
I just recently did a power stroke 3.5" exhaust with sraight thru muffler and modded a super duty downpipe to fit my obs turbo elbow. Also last fall I put in an injection pump from Midwest, those two things made a hell of a difference. I put a large trans cooler to supplement the factory one that was already plumbed. So it goes out of trans to liquid to air then in the radiator then to another air cooler then back. I noticed the torque converter stays locked down and the front seal did far less weeping even though I was sort of flogging it. I am at a point to where I want to buy a billet converter or do a zf5 swap...
Anyway, please give me some opinions/ experience, change, whatnot. Thanks
