Dirtleg
Well I finally got all my exhaust parts sourced for my turbo install.
I used a 3" to 2 1/2" header adapter for the turbine elbow flange. Had to grind a little off the flange OD but nothing major. $20 (per set of 2)
Got a 2 1/2" to 3" bell from the flange to the downpipe. $16
The downpipe I had bent at a local muffler shop. It's 3 inch with a 35* bend opposite a 30* bend on a 13 1/2" center. Unfortunately it's not mandrel bent but I can always change it out later. It's a little long on the ends so I can cut it to fit. $20
3" 90* bend for the bottom of the downpipe. Probably have to cut a few degrees off it for a straight exit under the truck. $28 (paid that for 3" stainless 90's a year ago)
3" to 4" bell to go from the elbow to the main exhaust pipe. $20
10' x 4" exhaust pipe. They had this one on the shelf at NAPA (truck center). lists for $7+ per foot but he let me have it for $5.22 a ft cause I'm a regular. $53
Napa part # 54387 4" over the axle tailpipe. $52.89 + $26 shipping. Not a stock item order only. $79
I get to assemble and weld it all myself. Going to tig it since my mig is in Virginia. I don't like stick welding .065 wall. I'll just have remove any and all aluminizing in the weld area. So grand total $236 in exhaust parts. Not too bad really as that's an in house price (all shipping included). If you add taxes it's right at $250.
Now I just need to make certain that I'm not lacking any other parts for the install and plan a day to do it.
Oh also I bought the crossover pipe from ATS as I didn't feel like messing with it. That and the grommets (I bought 2) for the turbo pedestal to the valley pan was around $80 including shipping. So really about $320
