This past summer I installed an aftermarket oil pressure gauge in my '88 e250. I have it T'ed in along with the stock one. It is a digital AutoMeter one. When I first installed it I would consistently have about 12psi hot idle and 37psi on the hwy with the cruise set at 65mph. It would follow the expected behavior. It would increase and decrease with load/rpm. As is got into the dead of winter and was consistently staying below 0*F the readings started getting weird. It would bounce around until it had been running at temp for a while.....sometimes almost 10psi. One second it would as 37psi and the next it would say 27psi and then back agian. Now that it is warmed up it has not returned to normal. It seems to get stuck at about 33psi. Oil pressure seems good. Pressure jumps the second I take off. In 3rd gear (c6 trans w/3.54) I have 30-31psi just maintaining 35mph on completely flat ground, but after that it is like the pressure doesn't want to go up. It works its way up to 33psi with the CC set at 65mph. Sometimes after cruising for a while it jumps up to the normal 37psi and stays there, sometimes not.
I am thinking that it is something with the sender and am going to order a new one. The reason I think the pressure is okay and the sender is bad is because if I am cruising at 65mph/33psi and turn off the cruise to let the van just coast the oil pressure stays right at 33psi until the speed drops to almost 40mph (all coasting with no throttle). I would expect there to be a quicker drop if I completely let off the throttle. I will also sometimes get a higher reading, by 1-2psi, when I lessen the throttle input (like going down a hill). Then I may lose 1-2psi when I add more throttle (like going up a hill).
I pulled my oil filter and verified that the oil pressure regulator is shut al the way. Van has 150K on it. I have had it for 30k and consistently maintain it. It is very clean for its age and appears to have been well maintained prior to me having it.
Besides a bad sender, is there anything else I should check. Is there something that could be gumming up that is preventing full flow to the gauge sender location. I ran some AutoRx through it when I first got is 30K miles ago. Is it possible that the pressure regulator valve spring is getting tired? Should I pull the oil cooler block and look at replacing or shimming the spring? Is there an oil additive that I should add to help boost the oil pressure a little?
I could just be paranoid, but I am wanting to drive the van for another 300K miles including family trips and towing. Thanks
