Freight_Train
Traitor to the brotherhood
Well,went by this week and picked up the heads from the new used engine that is going back in and found some stuff that didn't look good....other than walking in and seeing them impact out the head bolts!!!!YIKES Well,they showed me the injectors and one had a blown out copper washer.The lower half of the injector past the threads was rainbow colored from the heat and blackened.You could see the path where the exhaust went past the washer.Also,one injector had major rust scale just below the threads but north of the copper gasket.Looked at one pair of rockers and the valve end of one was VERY worn.Not long and that cylinder was gonna have real problems.The Cylinders all looked Top notch.Smooth.Whoo hoo.Cylinders had a good coating of even soot so there was no water intrusion....Again WHOO HOOO.Heads looked pretty good.No rust or noticable water intrusion or damage.I did notice thought that the pistons don't look like any IDI pistons I have ever seen.The fire slot is square and shallow compared to white lightnings.Does this mean I have a 6.9L-A engine?If so,I might have to baby this thing and make sure I don't blow up a land mark Ford engine.
