Well it is alive again, after 10 k on my rebuild I had developed a VERY loud piston slap. I swore it sounded like a wrist pin, it wasn't. Number one piston shrunk and that hole had 12 thou clearance. Rattled like hell when the engine cooled down after a hard pull.
Tore it down, new .020 Mahle pistons and they are the .010 shorter ones, .0055 clearance and all is quiet.
My advice dont reuse old pistons if the bore clearance is anywhere near max spec of .008, oh well live and learn
But while in there I got some studs from arp and put a bigger wheel in the turbo. The studs are not as high strength as their head studs but much better than factory bolts.
The shop I got the turbo parts from said the IDI turbo, factory and ats wastegated , is a TO4H, the compressor side I got is a super 60 trim.
It definately makes more boost low and with the fuel turned up some more has even better power than before, a lot less blowby, can't imagine why that would be.
Here are some pics, the service truck my buddy uses at work made removal and install nice. also the check ball holding mod I do, sorry for the blur. I can detail for later. and the pretty studs, 7 inches long from arp. The intake hat that I couldnt get a good pic of till now. enjoy
