Hello!
I'm in the process of putting my truck back together post-tranny swap, and am trying to figure out the cause of the side-to-side play in my transfer case gearshift lever. I found that the play is at the pivot point, where the through-bolt goes through and bolts to the side of the tranny. I took a few pictures and posted them here to show what I've got...it looks like the plastic bushings are supposed to be thicker, or there's something missing. Is that the case? Or, is the big bushing in the lever assembly itself too wide? Or, what's up?
BTW, in the third picture, the plastic bushing IS installed...just, the collar is partially broken, so you can see how much space there is in there...
Thanks in advance!
Thanks in advance!
