MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,702
- Reaction score
- 142
I am in the process of installing an electric-fuel-pump bypass.
My intentions are to have the electric pump in a bypass line that can be called upon for filter-priming, emergency use in the event of a mechanical-pump failure, and occassional emptying of a tank in the event I may need to remove one for whatever reason.
I have three electric pumps on hand, an old A/C unit that has 1/8NPT ports, a like-new Holley Red, and a brand-new-in-the-box Carter P4070.
Between the Holley and Carter, which is the superior pump ??
I understand the Holley mounts with the motor-housing up top; whereas, the Carter says to hang the motor down, such that the flowing fuel circulates throughout the motor-housing, thus cooling and lubricating the pump.
Also, the Carter has rubber bushings around the three mounting bolts; whereas, the Holley mounts solid to the frame.
Educated opinions, please.
Thanks.
Thanks.
